Hey, y’all. I could use some help diagnosing my issues with ABS if you wouldn’t mind lending your expertise. This was printed on a heavily modified Tevo Tarantula with authentic Titan and v6 hotend in a direct drive configuration. I’m using Zyltech ABS printed at 218C on glass (covered w/Aquanet) with a bed temp of 100C. I’ve also got retraction set to .4mm and coating set to .2mm in Simple3D
Am I printing too hot? Over-extruding? What is causing those zits?
I’m also thinking that maybe you’re printing really slow and really hot for some reason. But 218C is kinda low for real ABS. What are speeds set at for these things?
@Griffin_Paquette Yeah, he said 218C and that’s low for ABS, but a low ABS temp would have a difficult time blobbing that easy. I’m wondering if it’s much higher due to wrong thermistor table or something like that.
@Nate_T , do you have any pictures of top infill? That would help determine if you’re over/underextruding.
I’m not a pro but to me it looks like you’re printing too slow, don’t have enough fan speed and when you re-prime after a retraction, it’s pushing out too much plastic. This could be alleviated by turn on “coasting” (I use cura). You definitely have something wrong though because that benchy looks like it’s dying…
maybe you find something here https://www.simplify3d.com/support/print-quality-troubleshooting/
looks like “blobs and zits” - as mentioned by @ThantiK you always need to consider temp with printing speed. 218°C may be fine at 30mm/s but bad at 10mm/s. The reason is the time the plastic is hold on that temp within the nozzle and so compounds expand and want to leave, creating uneven flow - hence also internal extruder geometry play a role.
after changing the hot end did you reset the thermistor in the software to the E3D v6 values? They are not the same as the stock thermistor I would pretty much guarantee. See if you can get a point and shoot thermometer and check your temps.
