Hey, where can I find the 6900 series bearings? I can’t find them on Robotdigg. (Listed on BOM as 5972K164)
They are from fasteddies bearings: http://www.fasteddybearings.com/10-units-10x22x6-rubber-sealed-bearing-6900-2rs/
I purchased from Fasteddy also. Make sure you order 8. For some reason my BOM had 2 6900 bearings as 5972K164 from Robotdigg, and the 6 others from fast eddy. I would jsut order all 8 from Fast Eddy. Eric, is this a mistake or is my BOM messed up?
I will have to check the BOM
I’ve modified mine a bit, apparently to my own detriment
Odd, mine says 2 in the Robotdigg section, same as @Sean_B I’ll be sure to order them, thanks! Does it really matter what PSU I get if it has 24V 200W? I was thinking of this one: https://www.amazon.com/gp/product/B019RNKSNY/ref=crt_ewc_title_gw_3?ie=UTF8&psc=1&smid=A1THAZDOWP300U | but I don’t want to risk the PSU failing and frying my printer. Will the 40+ units of the same specs have cleaner power? Those are also UL listed.
Ok, thanks!
