On Smoothieboard v2 we want reverse polarity protection on the power inputs. On v1 we have it only on the main power input, but on v2 we’d like ideally to have it also on the mosfet input ( even though errors are extremely rare ).
The problem is it’s fairly expensive, we currently use a mosfet and a zener I believe ( see https://docs.google.com/spreadsheets/d/1vshB97WWt6Lceo59aggbdhRuXxTEhSL9lkotScR0oYE/edit#gid=0 ). but that’s like >$1. If we now have two of them that’s >$2 …
That’s a lot. Anyone has a trick or an idea for very cheap reverse polarity protection ? 12-24v, 0-20A.
A mosfet is awesome because it can handle the current without burning a lot of heat. Diodes usually have a decent voltage drop which results in quite a bit of heat generated. If you have it on the main input, why would you need it on the others? is there no regulator built in?
Unfortunately, mosfet is basically the best way at those currents. The zener is required since most mosfets have a Vgs(max) of 20v and thus 24v would damage it. If you limit voltage to 15v or so, you can ditch the zener.
Hey ! Thanks for all the answers !
So, we are aware of the different options ( diode+fuse, mosfet, etc ), that wasn’t really the question.
The question was more “do you know of specific parts ( as in : part numbers ) that are interestingly inexpensive and still do the job we need done here”. With all the talented PCB people around here I expect some of you have know parts we don’t.
Seems like it would be best to diode protect the low-current circuit/voltage regulated circuits, and design the MOSFET output side to be tolerant of reverse connection by clamping the bias. Should be possible to avoid using any extra high-current devices, I hope.
