Hey Peter van der Walt .
Hey +Peter van der Walt. I came across this issue with an SVG I was just cutting. I have a dotted line (on the right of the image) spaced at 3mm line, 3mm space. Instead, it decided to cut as a solid line the entire way along.
Exported GCode: https://drive.google.com/file/d/0Bzi2h1k_udXwOWtpMGdnSWlaQ28/view?usp=sharing
Original SVG file:
https://drive.google.com/file/d/0Bzi2h1k_udXwckswNzcwVVBsTkU/view?usp=sharing
Hope that assists with whatever the issue is.
+Peter van der Walt They were separate line segments. I broke it into separate chunks, but I will recheck it :slight_smile: All my other dotted lines worked.
+Peter van der Walt Actually, there was an invisible line over the top of all the individual segments :slight_smile: Thanks.
