Hey, me again. I’m using LINEARBLEND between colors, but I find the white that results out of this blend too dominant. What would be the best way to have a mix of the alternating colors wihtout the LINEARBLEND or are some options to TBlendType? Thanks in advance for your help!
Hi Giles-
What colors are you blending between?
Lots of different. I know that mixing RGB will result in white, so blending from orange to blue will result in white, I was just wondering if there was some sort of tuning you could do yourself to the blending.
You’re totally correct: blending from orange to blue will go “through” a pale whitish color.
What sequence of colors would you LIKE to go “through” when blending from orange to blue? What would your ideal blend be like between those two particular colors?
It’s a trickier question than it seems at first, but if you can answer this one clearly for yourself, it often helps figure out how to code to get what you’re looking for.
