Hey I need some help with this laser. Ive had it for 4 months (Bought preowned and seller used under 1hour)
Im cutting 3mm and 2mm acrylic, after a few months I finally got mirrors aligned and laser cut perfectly for 2 week. I basically had 6mm lifted from the regular cutting area. Eventually it started during in a certain corner and I started messing with it. At this point its just burning the acrylic and not even cutting through.
Im trying to figure out how to resolve.
1 Issue I noticed is I would use regular tap water, I looked inside the lens area and it looks like it might have gotten some contamination due to FL water?
Issue 2 is leveling the acrylic I’m cutting closer to the laser head.
Any help would be appreciated
Thanks
