hey guys. So I've started to mess around a bit with my support settings
hey guys. So I’ve started to mess around a bit with my support settings to find the best one, but after many many tries I’ve either got support way to hard to take off ( I’m literally cracking the PLA ) or way to easy to come off and fall during print. Anyone find the best settings? I’m using PLA 195C.
Ps: what temp should I put my heated bed at just got one and I’m not sure which temp is the best.
In S3D I generally use a single separation layer of 0.4mm for support, if I need a good surface, I’ll use 2-3 dense layers. As for PLA bed temps, 60c is about standard.
@Ax_Smith-Laffin awesome thanks
