Hey Guys, Is there a way to rotate your milling coordinates so that the
Hey Guys,
Is there a way to rotate your milling coordinates so that the resulting work is along the Y axis instead of across it, or is that something I have to do in the design software or Fusion?
I try to do everything I can in the design software to keep things clear and clean. It looks like neither Chilipeppr nor the Tinyg support the g68 g69 rotation gcodes. If you are simply swapping x and y you might be able to modify the Chilipeppr gcode iterator macho to swap them. I can do it easier and faster with the design software I use so it is not a useful thing for me can create more problems than it can solve by introducing anther step in my workflow.
I just changed it on Fusion. Not a problem.
