Hey guys, I just finished building a kossel mini, and have entered calibrations stage. I am finding that whenever I use the auto level probe the readings are different -what is the tolerance for the measurements?
what kind of probe are you using, did you build your machine from a kit or did you self source?
Ithe probe is a hex key(I bought from http://tridprinting.com) and I set the probe offset value in configuration.h… But I noticed that the readings on pronterface console output is not consistent… I am wondering if this is a sign that my belts are not tight enough or something?
I was too stuck with G 29 . Finally skiped it and started printing . Just make sure your endstop height are identical
