Hey Guys does anyone know if there is a way to control speed or
Hey Guys does anyone know if there is a way to control speed or flow percentage in @OctoPrint ? Its the one thing I really miss from repetier. Particularly Flow. Is it available in the dev versions?
You can do it manually from the gcode terminal using “M220 S[feedrate in percent]” and “M221 S[flow rate in percent]”.
Cool. Thanks!
Some controller boards will actually let you control the flow ratio and print speed with a knob.
@Whosa_whatsis tried it last night and worked great. Thanks for the tip!
