Hey guys, does anyone here knows why Slic3r makes this very long and erratic moves after retraction??? And how to stop it?!?!?
I don’t have a lot of problems with oozing, just some pimples here and there.
But when it starts doing this, it just destroys the outer surface with material that gets wiped.
It generally happens when printing small consecutive sections.
Check it out on the video.
@Andre_Frazatto I’m not sure but it definitely seems like a slicer setting. I just don’t know what would cause it to do that. There just doesn’t seem to be any logic behind it.
Probably something to do with an invalid model and possibly something like avoiding perimeters on travel move. Additionally it could also be the setting to keep the seam all on the same side (as it’s aligning to the side you set the seam to be on, etc) Do you have the seam set to be on a specific corner every time?
turn of Whipe befor retraction, i have it enabled and it is doing so too, and it has nothing to do with the model,
pro:tip: use http://gcode.ws to watch what moves it will make without printing it
