Hey everyone, I Use a Servo Z probe arm to auto level the bed
Hey everyone, I Use a Servo Z probe arm to auto level the bed on my Prusa i3 (older) and I have been having problems lately. The initial Z height is too high, none of the prints are sticking and the first layers look horrible. Normally to fix this I go into the marlin firmware and adjust the Z_PROBE_OFFSET_FROM_EXTRUDER. Now when I change this value, Upload and run the print again nothing changes.If anyone has any tips please help me out.
Remember to reset your EEPROM values to default when you reupload (M502)
Instead of using the firmware, M852 by itself should report the Z offset. Then you can change the Z offset with “M852 Zx.x” (x.x being the desired offset). Adjust using M852, then once you find the right setting do M500 to write that value to EEPROM.
@Fred_Hamilton Thank you, Now the first layer is almost perfect.
