i had the need for some more effective cooling today and as my custom carriage is still some time away i quickly did a new fanduct that offers some more concentrated air flow. It might not fit your needs but it does work quite good for me so i thought i’d share it.
See some render pictures attached - the duct is just the yellow part obviously
Regarding the print I did mine in Colorfabb XT CF 20 (PETG with Carbon fibre) and printed it upright without support (there’s just one small bridge that is a bit of a challenge, everything else is quite easy to print.
The hole on the left works with the screwhole in the default carriage but works the other way around i just attached it with a slightly smaller screw, therefore the hole in the duct is only 2mm.
@Helmi I took your design and modified it for the E3D Volcano. I am really surprised that more Eustathios/HercuLien builders aren’t using the Volcano. It is posted here: http://www.thingiverse.com/thing:1066144 (STEP and IGES files included). I haven’t printed this yet.
@Bud_Hammerton i have the volcano upgrade set lying here but didn’t have a need to use it until now. What are you printing primarily that gives you a need for it? Maybe i’m not printing big enough all day
