Hey everyone,
A question for delta bot owners: What design have you got, and what do you think the most significant source of lash is?
SeeMeCNC’s new ball joint arms look very close to zero lash - though the sprung belt tensioner problems from the olden days make me wonder whether a rigid tension device between arms wouldn’t be better - so I’m curious what the next big problem for delta stiffness is.
I’m dreaming of a 5-axis platform to test Bread on, and I want a delta as stiff as possible.
Just like @Mark_Fuller sais, acurracy of the whole geometry and good components. And there is no such thing as witch one is better, it’s just a matter of proper execution and good engineering.
Build errors go into deflection/displacement/deformations somewhere. Fix your joint backlash and it goes to the carriages. Fix your carriages and it goes into your effector. Fix your effector and now your rods are not beefy enough. Around and around.
