Hey all,
When putting together a j-head what do you guys use for glueing/holding in place the resistor & thermistor?
I saw something about using exhaust putty for the resistor.
Any other suggestions?
Hey all,
Fire cement
@Thomas_T_Sorensen I’m assuming that’s for the Resistor, not the thermistor?
I know where to get exhaust putty easily enough, no so sure on fire cement. I assume that used about fire-places?
only $900 you can get a perfect one!
I just hold mine in with kapton tape. The resistor you wrap with aluminium foil until it’s a tight fit.
Thanks @Richard_Mitchell Foil on the resistor makes sense and sounds like a good idea.
So as long as the thermistor is held generally in place it will do? doesn’t need to fit as well/tight as the Resistor. Well I have plenty of Kapton.
There’s a fairly good walkthrough for hotend prep at http://www.tantillus.org/Build_3.html#hotend and http://tvrrug.org.uk/hot_end
