Hey all. I've been using chilipeppr with my grbl controlled x-carve for 2 years
Hey all. I’ve been using chilipeppr with my grbl controlled x-carve for 2 years now. I recently have noticed that the xyz coordinates and the virtual carve no longer work on the screen when cutting. Cuts still come out right but I have no reaction on the screen. Anyone seen this? I’ve not updated the grbl firmware on my machine at all. Running windows 7 on the computer doing the cutting. Thanks for any help. -Malcolm
It’s probably a units issue. Do you usually use inches or mm?
There should not be a units issue with the grbl workspace. It’s my code that nuked some edge cases in grbl 1.1. and the grbl widget in the jpadie workspace.
@Justin_Adie I’ve had this issue for a while now since updating to 1.1
Sure. 1.1 speaks a different language to 0.9. You need to use the /jpadie workspace for 1.1.
If you are having troubles on that workspace then I need lots of info to help debug that. Typically what is needed is
  1. Full capture from spjs in verbose mode
  2. Note of all errors in the js console
  3. Full description of what is going wrong (ideally with video screen capture)
