The hotend was of course PID tuned and had a very stable temperature throughout the print. Feed rates were at a very normal 60 to 70mm/s, and both hotends have an 0.4mm nozzle.
If I started tuning extrusion widths and multipliers, I’d start influencing all kind of other parameters about the result as well, like layer adhesion, and I wanted the result to be (at least mechanically) as comparable as possible.
@ThantiK I would think it’s the other way around. The Aluhotend is made by a respected member of the RepRap community who also happens to be a forum admin. http://reprap.org/wiki/Aluhotend
My money is on QU-BD copying his design, not the reverse.
@Normand_Chamberland , QU-BD has been producing these nozzles since the MK7 or so. It’s a pretty common MakerBot nozzle. The history on the AluHotEnd only goes back to late 2013. So I think you are likely wrong in this case. The second, less sharp nozzle in the picture is a MG nozzle.
The wiki page history only goes back to late 2013… But you’ve been around the RepRap movement much longer than I (and I only in a lurker capacity) so I’ll defer to your arguments. I’ll admit I may be biased against QU-BD considering their bad rep.
I’ve got one of these on order… That I can change over from direct-drive to bowden without replacing my hot-end and the price was the two selling points. The JHead is going into the ‘backups’ box.
