Here’s another scrollsaw pattern of Mr. David Bowie. I did this one in 1/4" mdf as a test. Used Vcarve with a 1/16th inch bit feed was 40
Awesome! Could you share the file for this?
ah Okay, no worries! I’ll trace one myself
@james_shelton Actually I don’t seem to be able to trace it very well, could you email it to me at nick@makealittlemore.co.uk? thanks in advance!
Much appreciated!
What type of software do you have
my main CAM tools are Aspire and CamBam, Then I use HSM in Inventor for anything that needs very specific tool control.
Perfect! thank you
Very cool… How did you generate the artwork/gcode? I use Vcarve but I’m challenged to get a line drawing simple enough for a reasonable portrait. This one is nice!
@Colleen_McGuire I imported the jpeg into Vcarve used the trace function, deleted the jpeg then went to the tool paths selected my 1/16 th bit. And went from there
I find Vcarve raster to vector conversion quite good. Cleaning up the image first in Photoshop is key to making it easy. Posterize filter can reduce unwanted visual noise.
