Here's a screen capture.
Here’s a screen capture. I completely shut down the tinyg and rebooted my computer
Oh, don’t use 1.83. I removed the links to it.
I was using 1.80 with the same problem. What version should I use?
Use 1.80 as that is the latest version of SPJS that is 100% solid right now. 1.85 is getting very close, but not released yet. It is on Github though.
What those checkmarks with green and then yellow mean is that TinyG is not sending you anything back. CP and SPJS can queue in 255 characters of data into TinyG. That is represented by the green checkmarks. The yellow checkmark means SPJS has it in a holding pattern because it would overflow past 255 chars. SPJS sends you a black checkmark when it gets an r:{} response from TinyG for each line. Given that you have no black checkmarks your TinyG is NOT sending back any data.
BTW, you can turn off the funnel icon in the Serial Port Console to see the raw data coming back from TinyG.
