Here is my latest limit sensor that I use on my Shapeoko with Chilipeppr.
Here is my latest limit sensor that I use on my Shapeoko with Chilipeppr. It includes easy to remove wires, no crimping or soldering.
Here is a Youtube Link. https://youtu.be/ZiHUVPwZYS4
Mike! Looks great.
I like the terminals.
Ray,
That¹s the best part, there is a slot above each wire port. Stick a pin or
small screwdriver in there and it releases the wire. No soldering no
crimping and no destruction to disconnect. Check out the video I show how
to do it.
Yep, I originally posted while halfway thru the video, then 10 seconds later you show it and I edited my comment.
In case context unclear my original comment asked how to disconnect wire from terminal.
Yeah those are great.
I use pluggable screw terminal blocks for most things these days.
@Michael_Omiccioli I have been doing some research into building something like this for my OX CNC. Would you mind sharing your schematic and parts list. I have the hall effect sensors, the leds, proto board and resistors. I have created a version that has a single LED that lights up when the hall effect switch is activated. What I would like to do is show two LEDs as you did. One green for normal operation, it will turn off when switch is triggered and a red LED will come on. The Red will go off when switch is deactive and the green LED will come back on.
