Here is a not too expensive air dryer for those having issues with moisture in the air assist air source.
I had one of those . . . only lasted a couple of years.
Replaced it with this, which seems to be a much better built product:
https://www.ebay.com/p/?iid=131488655430
https://www.ebay.com/p/?iid=131488655430&&&dispItem=1&ul_ref=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-117182-37290-0%2F2%3Fmpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252Flike%252F131488655430%253Fchn%253Dps%2526dispItem%253D1%26itemid%3D131488655430%26targetid%3D340521012127%26device%3Dm%26adtype%3Dpla%26googleloc%3D9033717%26poi%3D%26campaignid%3D764892186%26adgroupid%3D39783961149%26rlsatarget%3Daud-296850005184%3Apla-340521012127%26abcId%3D978836%26merchantid%3D101501455%26gclid%3DCIr7lO-akNQCFUZrfgodaj8LuA%26srcrot%3D711-117182-37290-0%26rvr_id%3D1219498417964&chn=ps
Thanks, I’ll check out that link
I had problems with moisture on focal less added 1 inch wide by 1 meter length of pvc pipe filled with desiccant water absorbing crystals, worked great for 9 months ,then winter hit and was getting water again,added another meter of crystals problem solved,total cost $60
