Bought a made in china laser, trying to configure LaserWeb and dont have any info on what to set the Laser diameter to after loading a file.
Here are the specs from the laser I bought but dont see anything about the laser diameter.
Any help would be greatly appreciated.
Wavelength(nm):445nm-450nm
Input Voltage(v):12V
Operating Mode:CW
Cooling Mode:FAN+CASE
Transverse Model:Near to TEM00
Beam Diameter at the Aperture(mm):~6
Divergence,Full angle(mrad):<=4
Power Stability(RMS/4 hrs):<5%
Operating Temperature:-10~+35
TTL/Analog Modulation:TTL
Laser Head Dimensions(LWH):303050
Power Supply:PSU included
Expected Lifetime(hours):>5000
Package:BOX
Weight:0.3KG
