Good morning Don. It is me again.
Wiring a stepper motor to Fluid NC board . X Axis
I have a new Nema17 motor which has 4 wires. Red Blue Green Black
The red and blue are paired. Tested with a multimeter to read resistance
What color sequence are these wired to the 4 pin connector. What color goes to which pin?
Is the X axis wired the same as the Y axis motor?
Thanks for the help.
Alex
If a pair of colors show they are connected, it’s likely a two phase motor. And there is a connection for each pair.
You can’t go by color codes as a general rule…
No pictures or any other information is probably why you don’t have many responses…
Good luck
