Hi, everyone
On my DIY laser cutter the reference switches are located on the top left. (For mechanical reasons) I would like to have the 0-point of the whole machine at the bottom left (-330mm). I can do this with a G-code command after homing. G92 X0Y330Z0. After that everything goes as it should. The problem is the view in the main window. The Y-axis of the machine is then displayed from 330 to 660mm. What did I set wrong? I hope my explanation is understandable, otherwise please ask.
I only use the web version ( via browser) on an RPI 3B +. But shouldnât play a role for this topic, shouldnât it?
Dave
Settings.json:
âsettingsâ: {
â__versionâ: â4.0.999â,
â__selectedProfileâ: âDWâ,
â__latestReleaseâ: â2019-11-26T10:45:07Zâ,
âshowMachineâ: true,
âmachineWidthâ: 310,
âmachineHeightâ: 330,
âmachineBeamDiameterâ: 0.3,
âmachineBottomLeftXâ: 0,
âmachineBottomLeftYâ: 0,
âmachineFeedRangeâ: {
âXYâ: {âminâ: 1, âmaxâ: 50000},
âZâ: {âminâ: 1, âmaxâ: 50000},
âAâ: {âminâ: 1, âmaxâ: 50000},
âSâ: {âminâ: 0, âmaxâ: 30000}
âmachineXYProbeOffsetâ: 0,
âmachineZEnabledâ: true,
âmachineZMatThicknessâ: 0,
âmachineZToolOffsetâ: 0,
âmachineZStartHeightâ: â0â,
âmachineZProbeOffsetâ: 0,
âmachineAEnabledâ: false,
âmachineBlowerEnabledâ: false,
âmachineBlowerGcodeOnâ: ââ,
âmachineBlowerGcodeOffâ: ââ,
âpxPerInchâ: 96,
âforcePxPerInchâ: false,
âdpiBitmapâ: 300,
âtoolGridWidthâ: 310,
âtoolGridHeightâ: 330,
âtoolGridMinorSpacingâ: 10,
âtoolGridMajorSpacingâ: 50,
âtoolSafetyLockDisabledâ: true,
âtoolCncModeâ: false,
âtoolImagePositionâ: âBLâ,
âtoolUseNumpadâ: false,
âtoolDisplayCacheâ: false,
âtoolUseGamepadâ: false,
âtoolCreateEmptyOpsâ: false,
âtoolVideoDeviceâ: null,
âtoolVideoPerspectiveâ: {âenabledâ: false},
âtoolVideoLensâ: {âaâ: 1, âbâ: 1, âFâ: 1, âscaleâ: 1},
âtoolVideoFovâ: {âxâ: 1, âyâ: 1},
âtoolVideoResolutionâ: â720p(HD)â,
âtoolVideoOMRâ: false,
âtoolVideoOMROffsetXâ: 0,
âtoolVideoOMROffsetYâ: 0,
âtoolVideoOMRMarkerSizeâ: 20,
âtoolWebcamUrlâ: ââ,
âtoolFeedUnitsâ: âmm/minâ,
âtoolTestSValueâ: 1,
âtoolTestDurationâ: 0,
âgcodeStartâ: âG21 ; Set units to mm\nG90 ; Absolute positioning\nM3\n\n\n\nâ,
âgcodeEndâ: âM5 ; Switch tool offEnd\nG0 Z0 F5000\nG0 Y300X0F15000\n\nâ,
âgcodeHomingâ: â$H\nG92 X0 Y330 Z0â,
âgcodeGeneratorâ: âdefaultâ,
âgcodeToolOnâ: ââ,
âgcodeToolOffâ: ââ,
âgcodeLaserIntensityâ: âSâ,
âgcodeLaserIntensitySeparateLineâ: false,
âgcodeSMinValueâ: 0,
âgcodeSMaxValueâ: 255,
âgcodeCheckSizePowerâ: 1,
âgcodeToolTestPowerâ: 1,
âgcodeToolTestDurationâ: 0,
âgcodeConcurrencyâ: 2,
âgcodeCurvePrecisionâ: 0.1,
âcomServerVersionâ: â4.1.000â,
âcomServerIPâ: â192.168.0.40:8000â,
âcomServerConnectâ: false,
âcomInterfacesâ: [âUSBâ, âESP8266â, âTelnetâ],
âcomPortsâ: [
{âpathâ: â/dev/ttyAMA0â},
âmanufacturerâ: â1a86â,
âpnpIdâ: âusb-1a86_USB2.0-Serial-if00-port0â,
âvendorIdâ: â1a86â,
âproductIdâ: â7523â,
âpathâ: â/dev/ttyUSB0â
âcomAccumulatedJobTimeâ: 421,
âconnectViaâ: âUSBâ,
âconnectPortâ: â/dev/ttyUSB0â,
âconnectBaudâ: â115200â,
âconnectIPâ: ââ,
âjogStepsizeâ: 1,
âjogFeedXYâ: 10000,
âjogFeedZâ: 3000,
âmacrosâ: {
â*GotoXY0â: {
âkeybindingâ: âctrl+f1â,
âlabelâ: âGoto XY zeroâ,
âgcodeâ: âG0 X0 Y0 Z0\nâ
â*LaserOffâ: {
âkeybindingâ: âctrl+f3â,
âlabelâ: âHomingâ,
âgcodeâ: â$H\nG92 X0 Y340 Z0â
â390e1e93-9333-41c7-b2ec-1aa62326af7câ: {
âkeybindingâ: âctrl+f4â,
âlabelâ: âUnlockâ,
âgcodeâ: â$Xâ
â20869cad-f2c3-4481-bbaf-622473fba1dfâ: {
âkeybindingâ: ââ,
âlabelâ: âLaser Testâ,
âgcodeâ: âM3 S30â
âbd4f4e53-b16f-40e5-8f83-8c77a99e542fâ: {
âkeybindingâ: ââ,
âlabelâ: âLaser Offâ,
âgcodeâ: âM5 S0â
âb857d0f7-00a8-4409-a7d4-70419e9d564dâ: {
âkeybindingâ: ââ,
âlabelâ: âZ-40â,
âgcodeâ: âG1Z-40.7F5000\nâ
â3f684c1d-8261-47c8-94b5-fa3ed69bc10fâ: {
âkeybindingâ: ââ,
âlabelâ: âEntnahmeâ,
âgcodeâ: âM5 ; Switch tool offEnd\nG0 Z0 F5000\nG0 Y300X0\n\nâ
âuiFcDragâ: null
