Can anyone tell me if there is a software for Markebase Mks Robin Nano v3.1 that is made for infinite z 3d printer?, and which one printer printer use on bleckbelt cure ?
The official current firmware is:
You don’t say what printer you have, but here’s an example of configuration files for Marlin for a belt printer.
Hi, I have a custom printer I built with corexy kinematics with robin nano v3.1 motherboard, tf35 v2 display and tmc2209 drivers. When I try to install Marlin 2.1 bugfix, I encounter a white screen. No matter what I did, it did not work. When I install Marlin 2.0, text appears on my screen but images do not appear. When I install the software you shared, everything works fine, but I cannot add the 2nd driver (to the E1 slot) and the 2nd motor for the Z axis. . Please help I can’t find it.
That’s a different configuration. As far as I know, you have to compile with a changed configuration for that.
I’m not currently running Marlin at all, only klipper, so I am unlikely to be much help here.
