- Help connecting CNC with Marlin software *
Hello,
I just finished to build my own R-CNC machine, if you are not familiar with it more info can be found here:
https://www.makerfr.com/en/cnc/r-cnc/
The machine uses Arduino Mega + Ramps 1.4 to control the stepper motors with Marlin software.
I’m trying to test Chilipeppr to see if it can work with my R-CNC. I’m currently using this machine with MKS Gen V1.4 board running Marlin.
I downloaded Serial Port JSON Server from Github for Windows 10 x64 PC, opened the executable file, and found the USB port
of my machine connected to the MKS Gen board.
I opened Chilipeppr.com/tingyG, from the drop down menus on the bottom right side I chose Marlin as the OS and the correct baud rate of the machine.
I was able to connect (I heared a ‘clicking’ sound from my motors once connected), however I’m not able to control any of the axis of the machine, there’s no response at all.
Am I missing any step to make the machine to move, or it is just that Chilipeppr won’t work with MKS Gen or Arduino Mega + Ramps 1.4?
Will appreciate any kind of help,
Thanks!
