Hello TinyG users,
May I ask you to see if you can reproduce this erratic behavior - see the link for details. Machine must be in Y0 when setting $2tr value.
I use the following TinyG firmware:
[fb] firmware build 442.04
[fv] firmware version 0.97
i posted about this two years ago - using chilipeppr - whenever i change axis parameters, the direction is reversed for the initial move. though can’t confirm at the moment as the chilipeppr settings widget is borked.
