Hello there.
I am using GRBL based CNC with Chillipeppr and quite happy with that. I am wondering, though, is that possible to have different coordinate planes for G53, G54 etc in GRBL workspace similar like it is in Tiny-G
If Grbl supports these work coordinate systems, then yes, you could do that. Since Chilipeppr is open source, you could take the code from the TinyG widgets and port them to the Grbl widgets to pull this off.
@jlauer Thanks John. I am not fluent, by any means, with JS, I thought it is in somebody’s TODO or feature list…
Grbl supports g53.
