Hello peoples. This is the build start for my new improved CNC tabletop milling and engraving machine. I will be using the original machine to make parts for this new 960mm wide base plate. This build is based on what was needed to perfect the original 600mm wide machine.
Nice. What will the frame be built from?
Looks great!
Hola. Perdona las molestias. Pero, que motores estas utilizando? Gracias.
Hi. Sorry for the inconvenience. But what engines are you using? Thank you.
@marcos_a_santana_cas Another great question. This medium size machine will be getting twin NEMA23 motors on the Y axis and a single large NEMA23 on the X axis. The Z axis will be fitted with a NEMA34 Motor.
@aeknarin_tomcup Yes I like this it looks very professional. Looks like a large work area, you must share this machine with us.
- Robert Ritchie. Thank you very much for your answer. You have a very good project.
