My worry would be the straightness of the carbon rods. The rods in the BOM are spec’d to L/100x0.01mm (where L is the length of the rod). Looking up carbon rods I found one spec at 2mm/1000mm which going to cause a lot of binding.
One option to increase the max speed would be to use 9mm wide belts so they exhibited less stretching during fast accel.
FYI: From another list source, the Mosquito’s are delayed, again.
What material are you printing? Perhaps the Merlin will do what you need?
Speed: have you tried any benchmarks to see if it will make a measurable difference in time? If you are making lots of 1-2 smaller parts it may not be worth it. If you are making any quantity of 2-12 hour parts, yes, go for it. , https://reprap.org/wiki/Merlin_Hotend
