Looking for some guidance on to program parallel led strips
Instead of having a single long line of leds, looking to have multiple branches
, they either criss cross or double back etc,
Hence instead if a making a light travel down a “path” on one led strip, It need to travel down multiple branches, and at times step over parts of a branch
Hello Marc, Thanks for the links. Ill look to learn from them (I think I have a fair amount of catchup . )
Below sketch might assist. 1st diagram is complete layout. 2nd is it broken into two branches so no overlap. 3rd illustrates segments between joints.
Movement may travel across branches, or different segments in same branch.
For example B --> E --> A --> D
Ideally would like to make it so point travels along a segment, and then chooses the next segment randomly according to whats available (and then repeat travel / choose segment path etc )
For example when traveling form A --> D, the available choices for next segment are either E or C
That’s an interesting coding challenge. I think you can wire everything up as just a few (two?) strings because it’s all going to get sorted out/routed in code, so make the wiring as easy for you as possible.
How many pixels are you thinking?
How long is a side, say A to B?
I feel like I saw this sort of thing before (pattern moving up to a joint and then randomly going one way or the other) but can’t remember if it was by someone here or I saw it elsewhere. It looked really cool though. @Andrew_Tuline do you remember this sort of a display? It was in an infinity cube or dodecahedron or something.
And an alternate form of mapping where only the x,y coordinate of a pixel is put into an array.
Or you might come up with your own tricky way to route things around your layout. Like I mentioned though, however you physically lay it out and wire it shouldn’t really matter. All the trickiness will be done in code.
