Hello. Just arrived EleksLaser-A3 Pro 2500mW Laser Engraving Machine and I put it together
Hello. Just arrived EleksLaser-A3 Pro 2500mW Laser Engraving Machine and I put it together and tested it, works great. Now I need help with LaserWeb. I exported my PCB from eagle to .svg with eagle2svg-1_4_1.ulp. Can someone help me how to convert that image to vectors. Some video will be nice.
If has been corverted to svg should usually be vector. If not, LW has a vectorizer included, but cannot assure the good results pcb needs. Alternatively, use Inkscape to open svg and trace if needed.
And What to do now
https://profiles.google.com/photos/109061549344052081080/albums/6510573994230652161/6510573994340735714
Please navigate and read the docs to https://cncpro.yurl.ch you can check YouTube for video tutorials, too.
@David_Munka you can also look at my YouTube videos on how to create basic operations
I was trying to do something in inkscape but I don’t know how to use it.
Here is picture of svg in Inkscape.
https://profiles.google.com/photos/109061549344052081080/albums/6510576090292907793/6510576088795630274
Ty for now, I enjoy working with electronics and I learned everything mostly my self but cnc is a bit new to me.
@David_Munka
Nice One … Can i ask u question … your laser module can cut papar with how mush Cut Rate u enter
thanks because My laser can not cut even i useing cut rate :70 :frowning: and my laser also 2500MW …
