turgan_s
(turgan s)
August 18, 2015, 8:24am
1
Hello,
Is there any way I can fade my rainbow to YELLOW rather than Black using beatsin8?
I’m a newbie. Any help or guidance on which direction I should search this would be great.
fill_rainbow( leds, NUM_LEDS, hue16 / 256, 50);
uint8_t bright = beatsin8(100, DIMMEST, BRIGHTEST);
FastLED.setBrightness( bright );
FastLED.show();
Not using this technique, no.
I would try using a rainbow palette and then easing to a yellow palette.
Look here for basic palette usage:
master/examples/ColorPalette
The FastLED library for colored LED animation on Arduino. Please direct questions/requests for help to the FastLED Reddit community: http://fastled.io/r We'd like to use github "issues&...
Look here for smooth transitioning between palettes:
https://github.com/atuline/FastLED-Demos/tree/master/colorpal_beat
Make sure you are using version 3.1 of FastLED.
turgan_s
(turgan s)
August 18, 2015, 12:59pm
3
Hah thanks Andrew! just right now I was watching your youtube videos and you came for help… You’re a Fastled saint.
turgan_s
(turgan s)
August 24, 2015, 5:29pm
4
I’ve been working on palettes. The palette blending does not seem to be fast enough.
I might be wrong but:
In nblendPaletteTowardPalette the variable that controls the speed of blending from one palette to the other seems to be uint8_t maxChanges = 1-48.
I’m looking to blend these for matching the beat of a music ie.the brightness example https://plus.google.com/105509168812847732602/posts/2gWA97KBu5B?pid=6184804877453259650&oid=105509168812847732602 http://pastie.org/10372689 .Do you have any ideas what might be the solution to this?
working with FastLED 3.1 on Arduino Mega 2560 iii & Windows
