Hello, i’m wondering what could I use to put out the flames appearing while cutting. I’ve checked few ‘diy tutos’ on how to make an air assist but I haven’t found what machine they use to blow air.
Could a air pump (use to inflate mattress) work ? pic1
I don’t want to spend a lot of money (as i don’t have sadly ^^)
I need something that is enough powerfull to put out the flames but as i cut veneer with my k40, I don’t want it to blow my veneer pieces all lover the laser (and the vent to suck them up)…
Thank you in advance
Manon
im not sure on the gph but it puts out a steady stream that does extinguish the flames when cutting wood or similar materials, and doesn’t blow my material around.
@donkjr ok, i’m also considering buying an aerograph kit, do you think an aerograph compressor would be strong enough to put out the flames ? it’s only 10-15L/min (~1500GPH)
@Manon_Joliton Assuming you mean an “Airbrush Compressor”, I used to use one but it was way to noisy and no extra air capacity. Many use air brush compressors.
The noise from that indicator would drive me crazy. My current setup involves a 5$ aquarium air pump, vinyl tubing and a .35 welding tip. The tubing is zip-tied to a copper wire so it can be simed at the laser focus point.
I bought it locally and don’t have the package any longer but similar ones on Amazon sized for 10 gallon fish tanks list 1.8 l/min. I think it works because I’m not trying to fill a whole lens-surrounding nozzle, just pointing a jet of air right at the cutting location.
