I have followed and sometimes repeated the same sequence of steps in the LW4 tutorial, always with the same result leading me to believe that there is something wrong with SVG generated by Inkscape or with LW4 “Add Document” routine.
I believe the error “The file has minor issues. Please check document is correctly loaded!” is causing this problem.
I posted print screen of this problem for the LW community but I still have not had an answer: “The file has minor issues. Please check document is correctly loaded!”, LaserWeb 4.0.996 error · Issue #533
