hello, i would buy and build a reprap,
hello,
i would buy and build a reprap, but what is the 3d printer with the best value for the price.?
i see for prusa or mendel or a delta 3d printer but i have no experience whith a 3d printer.
thanks
I would opt for a Prusa i3 as a first printer since the’re easy to build and debug. The Prusa i3’s are available in a large variety in price and quality so the’re must be one that fits your needs and budget.
thanks!
and what electronic board i should use?
i’m seeing for RAMPS or megatronics… but i don’t find recent discussion.
RAMPS is outdated in my opinion. If you have the money go for something 32 bit.
at example?
I would like to spend the minimum possible
where i can find updated information for the electronics and the firmware.? i have searched but i found only old posts.
@simone_viozzi
I think a good starting point is http://reprap.org.
thanks, i have already visited this site but i can’t find what is the best recent 3d printer
@simone_viozzi Delta is not a good idea for your first printer especially if you’re gonna self source it. I would go with a prusa I3 from http://reprap.org and in terms of a board thats your call. Most can be configured fairly easily
@simone_viozzi
AFAIK RepRap is pretty agnostic about what the best printer is so you probably won’t find such a list on the website. The best printer depends on so many things: budget, experience, planned use (e.g type of filament) and so on.
Check out “tech2c” on youtube.
