Hello! I tried to use the autolevel widget with an Inventables Carvey.
Hello!
I have the contacts wired up correctly and as long as I only try to run a test probe with the autolevel, it works.
When I run the auto-leveling, it stops after the first point, and permanently stucks paused.
Tried to find out as much as I can from previous discussions, but none of them offered a solution so far.
I am using the Jpadie workspace.
I also can see an error in DevTools.
Thanks for the help!
My guess is that Auto-Level did not get updated to support Grbl 1.1 yet, so would you be up for forking and editing the Javascript code? I doubt there are too many changes to make it work.
Autolevel is up to date with grbl1.1. I’ve not seen that error before but I did make some changes a week ago in some code that is not exposed. Possibly some odd gremlin. I have some time in the next hour and will take a look.
fixed and patch pushed to GitHub.
I tried it today and am having the same issue as Adam. if I go to jpadie, it will run but pauses half way through the process. Anyone else try it lately
you need to post the feedback from the js console. without that information it’s very difficult to help you
ok which console is the JS console? :slight_smile:
