Hello, I printed this 6 way PVC connector. 4 of the 6 holes work.
Hello,
I printed this 6 way PVC connector. 4 of the 6 holes work. The top and bottom don’t but they are very close. I’ve had problems with other parts as well. I’m thinking I need to adjust the Z calibration?
What do I need to adjust? I’m using an Azteeg X5 Mini on my Eustathios Spider V2.
https://www.deltarap.org/printing-undersized-holes/
I believe you are describing vertical tubes that are not circular. First thing to look at is your xy tension and make sure it’s balancef
I have tightened up the belts. They were a little loose. We will see what happens.
