Hello, I have a LaserAxe laser, I used T2laser to flash it with laseraxe 1.1f grbl.
The issue I have is that my X axis moves in reverse. In T2laser there is an option to reverse the x axis. Is there a reverse axis function in laserweb? Everything else seems to work fine. Thank you in advance
I’m new to grbl, I’m very familiar with marlin. Do I just send the command as part of start script? Or do I send it at the command prompt every time I use the laser? Thank you in advance…
