Hello, I have 2 problems and don’t know if someone can help me.
This problem came after some weeks of use.
The laser power is not the same like you can see on the foto , a small space give a really different result
The engrave and the cut are not allineed using CorelLaser , before I never had this problem, when I start with 2 object one near the other start the problem.
I use also the ancor pixel , but never change
@Guido_Garzia It sounds like you need an optical alignment. Your beam is not travelling parallel to the gantry’s axis and therefore it is on a different place on the mirrors depending where you are in the x/y workspace.
I solved the problem of quality with the alignament, but I can’t still cut and engrave on the same job.
Down you can see a photo in the right a job with a pixel anchor , on the right without any pixel anchor. Before I can print centred without use any anchor.
I have unistall and reinstall Coreldraw X5 , I can’t try with LaserDraw because can’t do the same job I usually do with CorelLaser.
