Hello, how do I get the Pixel color of an LED with FastLED?
The pixels are just an array, and you can access it directly:
CRGB color;
color = leds[ i ];
There’s no function call required.
Let us know if you want any help and welcome!
Here’s how you define the color just pull up a patlette chart to choose a color. the 3 #'s in ()
leds[i].setRGB(0,255,250);
Here’s my FADE code here >>>
Put together & tested by:
Scottie Digital
#include “FastLED.h”
#define NUM_LEDS 288 // # of LEDS in the strip
CRGB leds[NUM_LEDS];
#define PIN 8 // Output Pin to Data Line on Strip
#define COLOR_ORDER GRB // I had to change this for my strip if your color is off then you know.
int fadeAmount = 5; // Set the amount to fade I usually do 5, 10, 15, 20, 25 etc even up to 255.
int brightness = 0;
void setup()
FastLED.addLeds<WS2812B, PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
void loop()
for(int i = 0; i < NUM_LEDS; i++ )
leds[i].setRGB(0,255,250); // Set Color HERE!!!
leds[i].fadeLightBy(brightness);
FastLED.show();
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if(brightness == 0 || brightness == 255)
fadeAmount = -fadeAmount ;
delay(9); // This delay sets speed of the fade. I usually do from 5-75 but you can always go higher.
I think the original question was how to get the color of a pixel, but if it was how to set the color of a pixel, there are a few ways to do it. Me, I usually just write an assignment statement instead of setRGB:
leds[i] = CRGB( 0, 255, 250);
or
leds[i] = CRGB::Aqua;
This way I can also switch it to use HSV colors just as easily:
leds[i] = CHSV( hue, 255, 255);
There’s documentation on the wiki here, too: https://github.com/FastLED/FastLED/wiki/Pixel-reference
Hello, thanks Scottie and Mark for your replies.
I’m currently using a APA102 LED strip on a small ferris wheel model. Could I get some suggestions/sample codes on what types of interesting LED patterns to use?
Now I already have the following patterns:
rainbow
theaterchase
cylon
all solid colors
How can I modify this Cylon code to make it work without delay(speed)? Because I’m multi-tasking my Arduino Uno, I can’t use any delay()
void cylon(CRGB c, int width, int speed) {
for (int i = 0; i <= NUM_LEDS - width; i++) {
for (int j = 0; j < width; j++) {
leds[i + j] = c;
FastLED.show();
for (int j = 0; j < 5; j++) {
leds[i + j] = CRGB::Black;
delay(speed);
for (int i = NUM_LEDS - width; i >= 0; i–) {
leds[i + j] = c;
FastLED.show();
delay(speed);
Check out the “DemoReel100” code, in particular the little function called “Sinelon”. https://github.com/FastLED/FastLED/blob/master/examples/DemoReel100/DemoReel100.ino
It basically just says:
void sinelon()
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy( leds, NUM_LEDS, 20);
int pos = beatsin16(13,0,NUM_LEDS);
leds[pos] += CHSV( gHue, 255, 192);
As for other thoughts on multi-tasking, you might also get some ideas from “TwoAnimationsAtTheSameTime” here https://plus.google.com/112916219338292742137/posts/FjfHnDP5tPK
Thanks!
How do I change the speed of “Sinelon”?
I tried to change the values in
it seems to change the length of the “Sinelon” and the speed. Is this the right way?
The first argument to the beat function is the number of repeats per minute.
To change the fade speed, play with the argument to fadeToBlackBy.
That help?
