Hello guys,
Today I have tried the auto level feature in GRBL workspace. The run probe test was successful but when I hit run the probing process ,probing stops after first point.
Does anyone encountered same problem?
Thanks.
Hello guys,
Thanks.
It’s still out there. 2 questions: what version of grbl firmware are you running? Do you experience the same problem at http://chilipeppr.com/imania ?
After comparing in a text editior, it looks that both /grbl and /imania workspaces are currently using the same code.
@jlauer @raykholo What was exactly the problem to be corrected (I cannot find the related post)?
@sszafran I copied the auto level widget from Imania exactly but in /imania the macro widget is changed (and broken) so I left that as the good one. You should see the different link for inserting the macro widget.
Well, different code anyways
