Hello Friends, i work on my XATC and found (maybe) a bug. But before i wrote an issue i’ll ask some guys here.
I’ll run a Touchprobe command (G38.2) inside of a gcode file, but in every case the board freeze at this command. The controller doesn’t answer on the serial console and i don’t got an error message.
I use build 442.04 cuz the last edge-build (449) freeze sometimes and is in this state unusable. Has somebody the same experiences and maybe a workaround for this? You see, i try to change the WCS and so on, but no luck.
Thanks
Frank
