Hello everyone, I have a question.
Hello everyone,
I have a question. Why Eustathios has three closed GT2 belts 1004mm, 994mm and 950mm? Can not use a standard size eg 976mm or 1140mm. Thanks
One belt is housed entirely underneath to drive both lead screws for the z axis. The other two belts run from the steppers underneath vertically up to the x and y-axis pulleys.
Thanks. 1004/994 is for X/Y and 950 is for Z. I think increase the size of the Z axis about 10 cm. So I want to buy two 2GT closed belts 1140mm for X / Y and 976mm Z axial. If I change the sizes of belts there will be no major problems?
