Hello everyone. I am very new to Arduino and my new Eleksmaker A3 laser. I was able to get the Eleks Mana SE 2 axis board and reflash it to the 1.1f firmware.
I was able to get it to run on the X and Y axis, and even got it to run to actual correct jogging dimensions. The problem I have is when I go to run a file, the X and Y steppers move appropriately however the 2.5W laser is not firing. It just runs on so you know where the laser is (super low power) but doesn’t burn, (not even on a piece of paper). Can anyone help me or does anyone have any insight on how to fix this so the steppers run the g code and the power is high enough to burn? Thank you in advance
Settings:
Gcode tab:
Gcode start = M4
Gcode end = M18
Gcode homing = G28
Tool on = M3
Tool off = M5
(also tried tool on and off blank)
Laser intensity = 1000
PWM Min = 0
PWM Max = 1000
Command box in the bottom right side of the screen
Must type code and SHIFT+ENTER
$0=10 :
$1=25 :
$2=0 :
$3=0 :
$4=0 :
$5=0 :
$6=0 :
$10=3 :
$11=0.020 :
$12=0.020 :
$13=0 :
$20=0 :
$21=0 :
$22=0 :
$23=0 :
$24=25.000 :
$25=500.000 :
$26=250 :
$27=1.000 :
$30=256 :
$31=0 :
$32=1 :
$100=80.000 :
$101=80.000 :
$102=80.000 :
$110=4000.000 :
$111=4000.000 :
$112=2000.000 :
$120=400.000 :
$121=400.000 :
$122=400.000 :
$130=300.000 :
$131=300.000 :
$132=200.000?
