Hello everyone, I am just starting to test Chillipeppr with my GRBL 1.1 on
Hello everyone,
I am just starting to test Chillipeppr with my GRBL 1.1 on Raspberry Pi 3 and for some reason the visualiser is not working. It starts as black screen then it takes anything on the screen as you can see from the screenshot. Can someone help me with this problem.
Thanks
Does raspi natively enable webgl extensions? From recollection it doesn’t and you have to jump through loads of hoops to enable it at OS and then at browser level. I recall posting some hints about it before.
Thanks for your response. I figured out that it is a webgl issue yesterday. You can enable the experimental driver on raspi very easy. I will test today and post m results.
Ok.
I’m not sure that the grbl workspace yet supports grbl 1.1. So you might want to downgrade to 0.9j if you are staying in that workspace.
@Justin_Adie It is if you go to the link on the upper left corner in pink. I tried that on windows machine and it was working fine for 1.1f
Yes. That is a different workspace.
