Hello everyone, I am having a little trouble after installing a new E3D hot
Hello everyone,
I am having a little trouble after installing a new E3D hot end. Getting the hot end installed, wired, and operational went without issue. But when it came to setting the new z-offset in firmware is where I am having trouble.
No matter what value I enter in for ‘Z_PROBE_OFFSET_FROM_EXTRUDER’
the Z height after probing does not change and runs down about 1mm or so into the print surface.
My setup: i3 RAMPS running Marlin with auto bed leveling probe via RC servo.
The value I am getting after setting all axes to 0 with the hot end placed just above the print surface is 11.80 (was 12.30 with the old J-head) with z-probe extended and 0.1mm raised after triggering the z-probe (11.80).
I have been able to adjust the probing travel speed successfully as well as z height after probing and the uploads to the board are going just fine.
It’s very weird, no matter what value I enter and upload for the offset the head goes to the same position, even if I set the offset to 15.00 or 8.00, I always get the same result.
Any thoughts?
You probably still have the old values stored in EEPROM. Use the following commands (particularly M502 and M503) to figure out what settings Marlin is currently using:
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default “factory settings”. You still need to store them in EEPROM afterwards if you want to.
// M503 - print the current settings (from memory not from EEPROM)
from https://github.com/ErikZalm/Marlin/blob/Development/Marlin/Marlin_main.cpp
Thank you @Thomas_Sanladerer , I will try setting to the eprom.
