Hello everybody
Sorry for the bad english.
I want to do pov stick with Attiny85
I can’t view bmp in this project.
also
Can I add micro sd card module
Thanks for your help now
project code
include < Arduino.h >
include < FastLED.h >
include < avr / power.h >
define NUMPIXELS 10 // Strig içindeki LED sayısı
define CLOCK_PIN 2 // Arduino’da “Pin 2”, yonga pimi # 7
define DATA_PIN 0 // Arduino’da “Pin 0”, yonga pimi # 5
define COLOR_ORDER RBG // şeriem BGR
define DÜZELTME TipikLEDStrip
Tanımlar BUTTON1 4
HEARTBEAT_LED 3 tanımlayın
// 11 x 10 = 110
IMAGE_LENGTH olanağını tanımlayın 110
IMAGE_WIDTH 10 tanımla
IMAGE_HEIGHT 10 tanımla
// resim [column_index * IMAGE_WIDTH + row_index]; argüman 0’dan başlayacaktır (IMAGE_WIDTH * IMAGE_HEIGHT -1)
// row_index ile 0 arasında (IMAGE_WIDTH - 1);
// column_index, 0 ile (IMAGE_HEIGHT - 1) arasında
// kalp
/ * const uint8_t görüntü [] =
{0,01,1,0,0,0,1,1,0,0,
0,1,0,0,1,0,1,0,0,1,0,
1,0,0,0,0,1,0,0,0,0,1,
1,0,0,0,0,0,0,0,0,0,1,
0,1,0,0,0,0,0,0,0,1,0,
0,0,1,0,0,0,0,0,1,0,0,
0,0,0,1,0,0,0,1,0,0,0,
0,0,0,0,1,0,1,0,0,0,0,
0,0,0,0,0,1,0,0,0,0,0};
/ * const boolean görüntüsü [] =
{1,1,0,1,0,1,0,1,0,1,1,
1,0,1,0,1,0,1,0,1,0,1,
1,0,1,0,1,0,1,0,1,0,1}; - /
// kalp transp
{0,0,1,1,1,0,0,0,0,0,
0,1,0,0,0,1,0,0,0,0,
1,0,0,0,0,0,1,0,0,0,
1,0,0,0,0,0,0,1,0,0,
0,1,0,0,0,0,0,0,1,0,
0,0,1,0,0,0,0,0,0,1,
0,0,1,1,1,0,0,0,0,0}; - /
// transp ve çevir
{ 0 , 0 , 0 , 0 , 0 , 1 , 1 , 1 , 0 , 0 ,
0 , 0 , 0 , 0 , 1 , 0 , 0 , 0 , 1 , 0 ,
0 , 0 , 0 , 1 , 0 , 0 , 0 , 0 , 0 , 1 ,
0 , 0 , 1 , 0 , 0 , 0 , 0 , 0 , 0 , 1 ,
0 , 1 , 0 , 0 , 0 , 0 , 0 , 0 , 1 , 0 ,
1 , 0 , 0 , 0 , 0 , 0 , 0 , 1 , 0 , 0 ,
0 , 0 , 0 , 0 , 0 , 1 , 1 , 1 , 0 , 0 };
ICSP başlığı, iğneye bakıyor (dişi kabloya bakmıyor):
1 MISO 2 VCC
3 SCK 4 MOSI
5 RST 6 GND
ATTiny85:
1 RST 5 VCC
2 NC 6 SCK
3 NC 7 MISO
4 GND 8 MOSI - /
CRGB ledleri [NUMPIXELS];
// BGR ile
// Kırmızı coef yeşil
// Yeşil sığır eti mavi
// bu yüzden mavi kırmızı
uint32_t timeNow = 0 ;
uint32_t heartbeatInterval = 500 ;
uint32_t lastTimeHeartbeat = 0 ;
uint32_t prog1_sweepInterval = 0 ;
uint32_t prog1_lastTimeSweep = 0 ;
uint32_t prog2_sweepInterval = 3 ;
uint32_t prog2_lastTimeSweep = 0 ;
uint8_t heartbeatLed = 0 ;
uint8_t buttonState = 0 ;
geçersiz ayar ()
eğer (F_CPU == 16000000 )
clock_prescale_set (clock_div_1);
pinMode (HEARTBEAT_LED, OUTPUT);
pinMode (BUTTON1, GİRİŞ);
digitalWrite (HEARTBEAT_LED, YÜKSEK);
FastLED. addLeds <APA102, DATA_PIN, CLOCK_PIN, COLOR_ORDER> (led, NUMPIXELS)
. setCorrection (CORRECTION);
için ( int i = 0 ; i <NUMPIXELS; i ++)
ledler [i] = CRGB ( 16 , 0 , 16 );
FastLED. setBrightness ( 32 );
FastLED. show ();
int8_t sweepIndex = 0 ;
int8_t sweepDir = 1 ;
uint8_t rainbowIncrement = 7 ;
uint8_t rainbowStart = 0 ;
uint8_t column_index = 0 ;
uint8_t row_index = 0 ;
geçersiz program_1 ( void )
rainbowStart = gökkuşağıStart + 1 ;
FastLED. setBrightness ( 96 );
fill_rainbow ( leds , NUMPIXELS, rainbowStart, rainbowIncrement);
için ( int ROW_INDEX = 0 ; ROW_INDEX <IMAGE_HEIGHT; ROW_INDEX ++)
// row_index ile 0 arasında (IMAGE_HEIGHT - 1);
// column_index, 0 ile (IMAGE_WIDTH - 1) arasında
if (image [column_index * IMAGE_WIDTH + row_index] == 0 )
ledler [row_index] = CRGB ( 0 , 0 , 0 );
// başka
// leds [row_index] = CRGB (32, 0, 32);
column_index ++;
eğer (column_index == IMAGE_WIDTH)
column_index = 0 ;;
geçersiz program_2 ( void )
boşluk döngüsü ()
timeNow = millis ();
buttonState = digitalRead (BUTTON1);
if (timeNow - lastTimeHeartbeat> heartbeatInterval)
lastTimeHeartbeat = timeNow;
eğer (heartbeatLed == 0 )
heartbeatLed = 1 ;
digitalWrite (HEARTBEAT_LED, LOW);
Başka
heartbeatLed = 0 ;
eğer (! buttonState)
if (timeNow - prog1_lastTimeSweep> prog1_sweepInterval)
prog1_lastTimeSweep = timeNow;
program_1 ();
FastLED. show ();
Başka
if (timeNow - prog2_lastTimeSweep> prog2_sweepInterval)
prog2_lastTimeSweep = timeNow;
program_2 ();
FastLED. show ();
