Hello Community Members, I need some help with a problem.
I am using a NodeMcu Esp8266, to run some FastLed Animation that can be changed with MQTT command. My problem is when ever the wifi/internet disconnects the animation freezes only to resume after the wifi/internet is back.
In India where data disconnection is very frequent with all ISPs it is a big problem, is there any way out of this?
Do you perhaps have some check running on a loop trying to connect back to internet? If so, that is probably the problem and you need to maybe try adding some delay to how often it tries again to connect. Maybe like trying to connect every ten seconds
@Reko_Merio Yes I do, and I tried adding delay it didn’t wotk. Seems like a inturrupt. When connection is lost and wifi tried to reconnect fastled probably cannot write the led animation sequence.
@Reko_Merio Thank you for the reply. While dint work however PubSub Client library does have a way to handle Reconection without blocking the main loop. That works well.
