Hello, anyone able to offer any advice on cleaning lens please?
I purchased ‘Diggers’ brand Isopropyl Alcohol (contains 100% isopropanol) and 100% cotton buds but it still leaves streak marks on the lens.
have I purchased the right solution for cleaning the lens?
I only very very lightly and gently wipe the lens with the wet bud, almost putting almost 0 pressure on it at all. Is it ok to put a little pressure when wiping it?
any trick for avoiding streak marks? personally I don’t understand I thought 100% isopronanol should evaporate 100%…
Not sure if it will work, but can you submerged the lens in a small container of the isopropyl & then clean it whilst submerged (with your cotton buds) & then take it out (by the edges only) & allow it to dry/evaporate off?
Use a dry cotton swab to wick up the residue you my have disolved solids that appear on the lens after evaporation. I start in the center of the mirror and work my way out in a circular pattern to wipe the mirror clean applying little to no pressure
i do not use cotton bud i spray the Isopropyl Alcohol onto lens then rub it back and forward on a lint free cloth ,holding by the edges and using a fair amount of pressure[you may have to repeat ] ,shine a torch at right angle to check if clean then turn over and repeat
it so little reflective coating on stock mirrors, it’s wise to go lightly, but you would go for better ones soon, air assist and good exhaust is helping a lot.
I second the use of eyeglass or camera lens cleaner wipes. Also, try starting with plain water. You may find you don’t then need to use the alcohol. Lastly, check the cotton swabs to make sure there are no additives (perfumes) that can end up as deposits/streaks.
